Run a script to all objects
By Caetano Brasil · 2011-01-26
Hi, Continuing with my simple questions about maxscript, I did myself (not easy for me) this very simple script, to apply an Edit Poly after the Base Object and execute the Quadrify command.
It works great for me, but I want to do it to the entire scene, or all selected objects. But, how to do it?
My script:
max modify mode
modPanel.setCurrentObject $.baseObject
macros.run "Modifiers" "EditPolyMod"
macros.run "PolyTools" "Quadrify"
Comments (7)
Caetano Brasil
renaming modifier
Ok, I want to do just one more thing:
How can I rename the new Edit Poly created? I want to rename "Edit Poly" to "Edit Poly Quad"...
Reply to Caetano Brasil
use .name prop
max modify mode
objs = getCurrentSelection()
for o in objs do
	modPanel.setCurrentObject o.baseObject
	o.modifiers[o.modifiers.count].name = "Edit Poly Quad"
Caetano Brasil
Both works smoothly, THANK YOU!
loop through selected...
max modify mode
for o in objs do
woops, forgot to refresh the page before post :)
br0t
--for selected
--for selected objects:
theSel = selection as Array
for s in theSel do
   max modify mode
   modPanel.setCurrentObject s.baseObject
--for all objects in the scene:
for o in objects do
Cheers
Reply to br0t
Caetano Brasil
br0t, your simple explanation just open my mind! I can apply this for a lot of tasks I do repeatedly!
Definitively, I need to study maxscript.
Again, thank you!
