Does anyone know if there is a simpler way to target the gizmo in the Unwrap UVW modifier (not the UVW Mapping modifier) and rotate it 90 degrees though maxscript?
I am currently using the unwrap5.setGizmoTM matrix but this isn't accurate enough for what I am trying to create.
Any help is appreciated.
Random rotate
randomly rotate uvw map mod
rollout t "Test"
local mymod = (UVWMap())
button b "Create UVWMap"
button b2 "Random"
on b pressed do
mapMod = UVWMap maptype:4
addmod = for i in selection do addModifier i (mapMod) ui:on
on b2 pressed do
obj = selection[i]
giz =obj.modifiers[1].gizmo
val = (random -360 360)
giz.rotation = (angleaxis val [1,1,1]) as quat
createdialog t
Hi John,
Now try with UnvrapUVW modifier :)
example
I came up with this
I use Box object with UnwrapUVW Mod with BoxMap projection
unwrapTM = $Box001.modifiers[#Unwrap_UVW].getGizmoTM()
tp = unwrapTM.translationpart
--rotate about Z-axis
rot = rotateZ unwrapTM 90
rot.row4 = tp
$Box001.modifiers[#Unwrap_UVW].setGizmoTM rot
Works great. Thank you for your help.
My pleasure
Cheers!
