Rotate selected Face in polyobj
By Michele Marcelli · 2015-06-23
How Rotate selected Face in polyobj?? Honestly I can not ...
I have this situation:
Select a Source poly face of object
Select a target poly face of same object
Press button and the target face it's positioned in the same face/normal rotation (similarly it has a copy and paste)
Now, I was able to extrapolate the transformation of the normal face, but I can not turn the face target...
Any help?
Michele Marcelli
Thanks Miauu for the reply.
No case in particular; sometimes the use of "make planar" or "align" does not match what I want (in all cases)forcing me to move vertex to vertex for align two face. Here the idea to take the transformation of a face and put it on the face target (just copy&paste).
Thanks for your patience and attention :)
To move a face/poly you hve to move its vertices.
Can you show an image of the final result?
