How would I create this same script but without the hassle of using the point object and just modifying the actual objects pivot?
I'm trying to rotate a pivot to look in the direction of a target with an axis constraint.
To test just create a bunch of boxes on different position in 3d space and then create a sphere at 0,0,0 using that as the target.
targetObj = $Sphere001
sel = selection as array
for obj in sel do
--pivotLookAt obj $Sphere001
local dummyPt = point()
dist = obj.pos - targetObj.pos
dist = normalize dist
upVec = [0,0,1]
dp = dot dist upVec
t = acos dp
c = cross upVec dist
c = normalize c
dummyPt.transform = obj.transform
dummyPt.dir = c
dummyPt.pos = obj.center
in coordsys local rotate dummyPt (eulerangles -90 0 0)
in coordsys local rotate dummyPt (eulerangles 0 0 -90)
worldAlignPivot obj
theRot = dummyPt.rotation
in coordsys local obj.rotation *= theRot
obj.objectoffsetrot*= theRot
obj.objectoffsetpos*= theRot
delete dummyPt
Comments (12)
well that is the code that i need thanks for sharing this with us.
dry cleaning epos
no biggie Jack :P
I think this works. I'll let you know how it goes. Thanks for the help Ralph
hey grant, have you tried the code i suplied?
with it you just gotta make sure to set yAxis to the local y of the object to rotate
to wrap it in a method:
I tried to implement this, the following doesn't work even though it seems to match the answer given by Graph.
Thoughts on what I'm doing wrong?
like this?( local pivPos =
like this?
yAxis should of course be the teaPots's local y vector
The attached image just clarifies what I'm after.
I just have a selection of objects who's pivots I want to point in the direction of a "targeted object"
It's just a one time deal. The user runs the script and it just changes the pivots rotation accordingly.
It would rotate them in a way that points the Y towards the target object while maintaining the Z axis pointing directly up, perpendicular to the ground.
do you need it in realtime?
if not the simplest way is to rotate the object.tm by (anle*axis) and then set the verts to their old coords ;)
assigning?
I'm not sure how you are assigning this to the objects pivot?
objectPoint3 = $Sphere001.pos
pivotPoint3 = $.pos
PivotZVector = [0,0,1]
theAngle = acos(dot(normalize (objectPoint3-pivotPoint3)) (normalize (PivotZVector)))
theAxis = normalize(objectPoint3-pivotPoint3)
correct, if the pivot is currently pointing up ;)
pseudoCode:pivot.angleAxisRo
pseudoCode:
pivot.angleAxisRotation axis:normalize(objectPoint3-pivotPoint3) angle:acos(dot (normalize (objectPoint3-pivotPoint3)) (normalize (PivotZVector)))
that should do it ;)
edit: "I'm Batman"
replacing variables
Would this be used in place of the PivotZVector Batman? PivotZVector = [0,0,1]
objectPoint3 = (object to which pivot will be pointed towards).position
pivotPoint3 = (currently selected object wishing to change).position
