Is there are way to affect the rolledUp state of a rollout AFTER it has already been added to the subRollout? I would rather not remove and re-add it as this would chance the order in which it is scene in the subRollout.
RolledUp outside of AddSubRollout
By Michael Taylor · 2011-10-17
The Answer
So a fellow student figured it out, the property I was looking for is .open not .rolledup
Hmm....
this is a different story then.
Holy...
thanks a lot man.
This saved me from a potential downward spiral of many many hours.
Was very close to go with the remove, re-add with a new state, plus saving all the variables.
Write it in stone: "Subrollouts have an '.open' write-read property that will trigger the rolled-up and rolled-down state."
bad news...
Yeah, Michael is right that no way to change RolledUp state without removing and readding the rollout.
If only the order of rollouts is what bother you, then #category property is the cure ;) Try this out:
But frankly speaking, i not find this useful at all, because i lost all variables and controls settings on the readded rollouts. So, as i said, if only the order is the issue then you've got the cure.
Cheers!
P.S. Well, to reply more complete s'd say that RolledUp() exist as event, but fired from script only the event is triggered and the actual RolledUp state not changed. Try this out:
The last 2 calls trigger RolledUp events but not change the state. So the method is there but it's broken (or unfinished exposed).
Yeah there is a property which allows you to adjust the state in which the subrollout is rolled up or rolled open.
Just check the help file for subrollout.
You are thinking of addSubRollout [rolledUp:] I know about this but it would force me to remove and re-add the rollout to the subRollout any time I wanted it to simply be rolled up, this would also change the position of it with others in the subRollout. I'm looking for a solution that allows me to simply roll it up or down if something in a list box is picked.
