Hello everyone, I'm currently working on a GUI for a rig that I'm building and am having some trouble getting a rollout in a floating dialog box to update with the changing of a custom attribute. Below is an example of my current setup, but I'd like to be able to set the rollout: and ui: of the Custom Attributes to the floatingGUI_rollout spinners, or achieve a similar result so that I can animate the custom attributes and have the GUI update to display the correct values.
I currently have a rollout stored in the CA that displays a single button that launches the GUI, and then the GUI rollout made within that. Any help is greatly appreciated, thanks!
Example_CA = attributes Example
parameters ExampleGUI_param --rollout:(I'd like this to feed into floatingGUI_rollout)
Weight_right type:#integer animatable:true default:100 --ui:(I'd like this to feed into spn_RWeight)
Weight_left type:#integer animatable:true default:100 --ui:(I'd like this to feed into spn_LWeight)
rollout LaunchGUI_rollout "Launch GUI"
button btn_LaunchGUI "Launch GUI"
rollout floatingGUI_rollout "Floating GUI"
spinner spn_RWeight "Right Weight"
spinner spn_LWeight "Left Weight"
on btn_LaunchGUI pressed do
createDialog floatingGUI_rollout 300 380
custattributes.add $ControlNode.modifiers[1] Example_CA
Comments (11)
hehe, yes I haven't thought of it first ... it would be even better if we can say no to add it by default because with a lot of rollout it may cause some flicker, I haven't tested this yet :-)
Martin
Cool ! I miss to thought of removerollout :)
I've found a much cleaner way while playing with it and it allow you to bind it to the parameters :-)
Martin
floatingGUI_rollout can also be local if you want :
this is the instance of the plugins, so if you have many object with different rollout you need to open this var will be replaced to point to the right parameters.
I destroy the dialog in case it was already open to make sure we don't get duplicate.
as for the idea itself, well it's not that bad, sure you have to manually reflect the change of every parameters...but like you said, I don't think you can bind it externally :-)
Martin
edit : I also destroy the dialog in case you have on close stuff to do, but in this case that not absolutely necessary.
Hmm, is not very useful idea... make both rollouts global to can reflect changes - ok, but finally parameters block not wired to them.
hey cool it works :D but I don't fully understand why. Can you explain what this part exactly does:
What is "this" doing? And why destroy the dialog?
Thanks for your help!
require some trick, but that sould work :-)
<code>
rollout LaunchGUI_rollout "Launch GUI" (
on btn_LaunchGUI pressed do (
global g_param = this -->we send this to the global space so that new rollout can access it!
global floatingGUI_rollout
try (destroydialog floatingGUI_rollout) catch()
rollout floatingGUI_rollout "Floating GUI" (
spinner spn_RWeight "Right Weight" range:[0, 1000, g_param.Weight_right]
spinner spn_LWeight "Left Weight" range:[0, 1000, g_param.Weight_left]
on spn_RWeight changed val do g_param.Weight_right = val
on spn_LWeight changed val do g_param.Weight_left = val
</code>
Martin Dufour
edit :found it, hum no not quite , what's the easy way to remove hmtl tag from ?
edit: ho well, I give up :-)
I've been house sitting without internet the past couple weeks, so sorry I posted this and then wasn't active on it. But I wanted to thank you guys for the replies, it's helping a lot to get this control setup the way I'd like it to!
Seems impossible to be on the floating dialog.
I would really like to know that, too!
Maybe you could wire your spinners to the values you want to change, when your rollout is created (with the "paramWire" stuff). But that would be kinda unflexible.
So how to create a script that adds custom parameters to an object, which you can then wire to anything you like and always be able to change them inside the floating gui?
