I’m doing multiple projects for the same client using a Revit template which I load in Max. I have a set of materials saved in a material library. I’m looking for a script to go through and assign my named set of materials to a list of objects with standardised names.
I’ve found many similar requests but I have zero Maxscript knowledge. I’m IT savvy and can code HTML and a bit of JavaScript but the examples I’ve seen have all been quite specific.
Would very much appreciate any help!
reader
Auto-assign materials related with the 3d work. Is you know about this https://bestbritishwriter.com/oxbridgeessays-com-review/ site then you must share your work with me. I know that you really share and really want to know about the work which we are doing in this time.
good idea
use xml ,json or db file , you have to know code c# in revit and maxscript in 3dmax
