reverse Filter String until FileDoesExist
By JokerMartini · 2011-07-28
I want to create loop that runs through a string until it finds the first DoesFileExist == true and then execute the script.
for example:
varString = C:\users\mike\donuts\bunnies\v01
(run backwards through string checking until true) varString
C:\users\mike\donuts\bunnies\v01 = FALSE
C:\users\mike\donuts\bunnies = FALSE
C:\users\mike\donuts = TRUE
stringn = "C:\Users\Joker\Desktop\cool\maybe\v01"
for i=1 to stringn.count do
tempStream = (substring stringn 1 (stringn.count as integer - i))
isValidDir = doesFileExist tempStream
print tempStream
print isValidDir
JokerMartini
Thank you Anubis for helping out.
my logical mistake :)
it happens often when i write a directly to the site without testing :) so, thanks for asking. Now the While loop not break due to the boolean test (pathParts.count > 0) that return true to the end. So, here is fixed function:
fn searchPath str = (
	local result = ""
	local isValidDir = false
	local pathParts = filterString str "\\"
	for n = pathParts.count to 1 by -1 while not isValidDir do
		local tmpStr = ""
		for i = 1 to n do tmpStr += pathParts[i] + "\\"
		if (isValidDir = doesFileExist tmpStr) do result = tmpStr
	result
JokerMartini
Anubis
When I run the code below it returns = "C:\"
When in reality the folders go as deep as = "C:\Users\Joker\Desktop\cool\"
So it should be returning that = "C:\Users\Joker\Desktop\cool\
Why is that?
myPath= "C:\Users\Joker\Desktop\cool\maybe\v01"
local result = ""
while pathParts.count > 0 or not isValidDir do (
local tmpStr = ""
for p in pathParts do tmpStr += p + "\\"
deleteItem pathParts pathParts.count
result
searchPath myPath
I think you can optimize a bit the function if you kick out the 'return' call. Something like ... (I write it on-the-fly, ie not tested):
	local result = ""
		local tmpStr = ""
	result
JokerMartini
solution if anyone needs it!
fn searchString = (
pathParts = filterString stringn "\\"
while pathParts.count > 0 do
testString = ""
for p in pathParts do testString += p + "\\"
print testString
isValidDir = doesFileExist testString
if isValidDir == true then
return tempStream
dirThatExists = searchString()
