How to reaveal location in explorer so that windows explorer will open and the file will be selected(just like in max)!
REVEAL LOCATION IN EXPLORER
By artrender · 2013-02-28
Thx!
SOLVED!
Thank you so much!
The last question is how to make /select argument work?
you can add /select if only one file... see the MS :
the problem with this
If I put
I want it to work all the time locally and from network, and when I use "//s003/folder/001.jpg" I want it to open the folder and inside this folder I want 001.jpg selected
It needs to be like this, with "explorer.exe" first, as that's what you're launching:
shellLaunch "explorer.exe" "d:/folder/"
For network locations, try "////location/derp.jpg" (i.e. use two more // at the start)
shellLaunch "explorer.exe" ("//")
