EDIT (2014-07-11): Antomor replied with a version reduced to just 2 lines. This will give you a string array of file paths rather than the actual bitmap instances, though. Use Anubis' getClassInstances version below for bitmapTexture instances.
for obj in selection do join ff (usedMaps obj)
ff = makeUniqueArray ff
print ff
EDIT (2011-12-20): As Anubis pointed out there is a much much better way to do this. Really to the point where there isn't any reason to make a function for it, but here is a better version anyway:
fn GetBitmapTextures theObjects =
texMaps = #()
for obj in theObjects do
join texMaps (getClassInstances bitmapTexture target:obj asTrackViewPick:off)
makeUniqueArray texMaps
texMaps = (GetBitmapTextures selection)
for texMap in texMaps do print (texMap.filename)
OK
ORIGINAL:
-- DON'T USE THIS. Keeping for search keywords.
Hey all,
I wrote a quick function for getting all the textures associated with an object. It seems like something a lot of other people might also need so thought I'd post it up. I've seen a couple similar functions out there, but non of them really seem to take into account either MultiMaterials, or maps that might contain submaps (like normal maps).
Thanks to the-generalist.com for posting this resource, which didn't do what I wanted, but still was a great starting point.
Just do GetBitmapTextures [object] and it will return an array of bitmapTexture maps. From there you can get/set any of the properties.. like returnedArray[1].filename for instance.
-- Because some submaps can also contain submaps we have to collect materials first, and then still append subMapContainers in the loop bitmapTextureMaps loop
subMapContainers = #()
if obj.material != undefined then
submatcount = getNumSubMtls obj.material
for i in 1 to submatcount do
append subMapContainers (getSubMtl obj.material i)
append subMapContainers (obj.material)
bitmapTextureMaps = #()
for subMapContainer in subMapContainers do
subtexcount = getNumSubTexmaps subMapContainer
for i in 1 to subtexcount do
theSubTexMap = (getSubTexMap subMapContainer i)
if theSubTexMap != undefined then
if (getNumSubTexmaps theSubTexMap) > 0 then
append subMapContainers theSubTexMap
else if classof theSubTexMap == bitmapTexture then
append bitmapTextureMaps theSubTexMap
makeUniqueArray bitmapTextureMaps
texmaps = (GetBitmapTextures selection)
for texmap in texmaps do print (texmap.filename)
Comments (10)
good work vallex , just as barigazy said .... need some case of thing .....and will be done...also need some consideration of vray disp map, displacement map thing, env...and else.
atomor fn is good but not return class bitmap instead filename only, for in anubis , its not really work on max 9 when object using mental ray material
simpler code
return all textures of selection objects
Added your version. Thanks, Antomor.
I made this one, it works fine:
Tested with most of materials and maps
Your fn have limitations. You will need to consider much more map types
it does not work for blend materials
-- Unable to convert: undefined to type: MtlBase
I mean your second code, but the first works! THX
... hahahaha.. man.. well thanks..
what about ...
I edited the post. Thanks again :P
