I`m quite new to scripting and a bit stuck. Could you guys help me out?
I`m trying to add a ColorCorrect map to all selected Bitmaptextures.
At the moment the script does add in the ColorCorrect map, but it creates also an instanced version of the ColorCorrect, which i don`t need or want :).
local SelView = sme.GetView sme.ActiveView
local SelNode = SelView.getSelectedNodes()
for sn in SelNode do
Temp = sn.reference
AssignNewName Temp
CC = ColorCorrection()
CC.map = Bitmaptexture()
CC.map.filename = Temp.filename
AssignNewName CC
replaceInstances Temp CC
A second issue I`m having is that when I edit the code so it works for fstorm, max just crashes. The creation of the new nodes works like it`s supposed to, but when using replaceinstances to replace the selected bitmap, it crashes.
temp = sn.reference
AssignNewName Temp
CC = FStormColorCorrection()
CC.input = FStormBitmap()
CC.input.filename = Temp.filename
AssignNewName CC
Kind regards
