Repeat Script delete
By Mrjacks2o · 2022-01-06
This is my script..
It merges all the Objects Named "Box03" in All the Max files within that folder.
Then plays an actions for each object it merged sometimes it can merge up to 50 objects how can i make it repeat the Action field for each object that it merged named "Box03" before it Prints "done"
thanks in Advance
mergeObj = #("Box03")
files = GetFiles "C:/Users/Workstation\Desktop\AdScript/*.max"
for f in files do
MergeMaxFile f mergeObj
--Action field--
select $Box03
$.wirecolor = color 138 8 110
$.primaryVisibility = on
max quick render
delete $
Print "Done"
	for f in files do
	--Action field--
        objsArr = for o in objects where o.name == "Box03" collect o
	for i = objsArr .count to 1 by -1 do
		objsArr[i].wirecolor = color 138 8 110
		objsArr[i].primaryVisibility = on
		max quick render
		delete objsArr[i]
	Print "Done"
	for f in files do
	--Action field--
	for o in objects where o.name == "Box03" do
		o.wirecolor = color 138 8 110
		o.primaryVisibility = on
		max quick render
		delete o
	Print "Done"
Reply to miauu
Mrjacks2o
Thank you.
Only Problem when it gets to delete o it doesn't loop it stops after it deletes.
But when i remove delete o it loops all actions.
what can cause delete to make the loop stop?
Reply to Mrjacks2o
obaida
Try this
	files = GetFiles "C:\\Users\\Workstation\\Desktop\\AdScript\\*.max"
	for f in files do (
         	if (MergeMaxFile f mergeObj) do (
	         	local o = getNodeByName  "Box03"
	        	max quick render
	        	delete o
	Print "Done"
