Hey guys! I am pretty stuck. I am 95% there on my script and the padding is giving me an issue. Was hoping someone could help tell me why I am having this problem.
Problem: After my first render, if I change the padding, it doesn't render out the new padding amount. I am not really sure why. It seemed to update in the render after I updated at least the save location and padding... sometimes.
I am not clearing the bake elements because I would like to keep it there. Idea is to setup using predefined preset in the script, render, tweak some settings in it, and then render again.
global bp = $.INodeBakeProperties
global prjp = $.INodeBakeProjProperties
fn RTTBigleyCastTools Xsize Ysize channel padding fullfilename =
bp.bakeEnabled = true
bp.bakeChannel = channel
bp.ndilations = padding
fPath = getFilenamePath fullfilename
fName = getFilenameFile fullfilename
fType = getFilenameType fullfilename
be.outputSzX = Xsize
be.outputSzY = Ysize
be.filenameUnique = true
be.filename = fName
be.fileType = fType
render rendertype:#bakeSelected outputwidth: Xsize outputheight: Ysize outputfile:(fPath+fName+fType) vfb: false
-- Sets up a Test Normal Map RTT Element
bp.removeAllBakeElements()
bp.bakeChannel = 1
bp.nDilations = 4
prjp.hitMatchMtlID = true
prjp.enabled = true
prjp.warnRayMiss = true
nmtest = Normalsmap()
nmtest.enabled = true
nmtest.outputSzX = nmtest.outputSzY = 512
nmtest.filenameUnique = true
nmtest.elementname = "Normal Map Test"
nmtest.filename = (maxfilepath + $.name + "_nmtest.tga")
bp.addBakeElement nmtest
-- Renders and Saves bitmap
be = bp.getBakeElement 1 -- Assigns the obj bake element to the variable be
RTTBigleyCastTools be.outputSzX be.outputSzY bp.bakeChannel bp.ndilations be.filename
if be.bitmap != undefined do
newbitmap = bitmap be.outputSzX be.outputSzY
copy be.bitmap newbitmap
newbitmap.filename = edtFilePath.text
display be.bitmap
save newbitmap
close newbitmap
close be.bitmap
)Any help would be very much appreciated.
padding isn't the problem
ok so what it is..
the display be.bitmap is displaying the same image from the last render. If I move objects around and rebake, I get the previous render.
so the close be.bitmap isn't closing it out?
I normally close it first before I do anything. But I gave it a shot trying to open it, bake, and then close it... and it is still a no go.
If I set the padding to 2, render, I get a render with a padding of 2. If I go back and change the settings to 64 (regardless if I change them in my script or the actualy panel), render, I will get a render with a padding of 2 (should be 64).
I have tried so many different things and nothing seems to be working.
i found that RTT stuff sometimes not work properly.With RTTAssist there was some problems that I solved by doing the following: open the default RTT Dialog, bake close the default RTT dialog. You can check the ToTex and RTTAssist code.
