Rename texture name for IFL file
By andrej · 2019-07-27
Good afternoon.
You need to rename the textures used in the scene.
The forum has a page "Rename texture name" http://www.scriptspot.com/forums/3ds-max/scripts-wanted/rename-texture-n…
There's a code
theMaps = getClassInstances BitmapTexture
for i in 1 to theMaps.count do
fileName = theMaps[i].filename
newFilename = getFilenamePath fileName + "\\map_" + i as string + getFilenameType
fileName
if renameFile fileName newFilename then theMaps[i].filename = newFilename
The code works fine if the scene uses a texture like ".jpg", ".psd", and so on. My scene uses textures like IFL.
I use two sets of textures in my scene. The first set is high-resolution for the final rendering, and the second is low-resolution for creating the preview file.
In my work, the main question is the time spent on creating the preview file. Therefore, use Assets Tracking, is not a solution.
Thus, there are two sets of textures and two sets of IFL files,for high and low resolution.
Simple IFL file renaming does not work.
It is clear that it is necessary to rename both a IFL file and the separate file used in this IFL file.
Is there a graceful way to handle this renaming?
