Rename Object to Group name
By asymptote · 2015-03-23
I have a scene with with 1,400 single objects each within it's own group. the objects are named object001. 002,003 etc etc, and the group has the name I want the object to be.
Is this possible via maxscript ?
tia
Comments (12)
alnoman
Heroes are there
But you still can use "interactive renamer" from here in scriptspot.
crystal3d
works on the whole scene
happy that i tested on a test scene,
can we get one that works on the selected group only?
and without numbers?
Or if you not like random unique name numbering then use this fn
fn renameGroupMembers groupNode &hendles sufix =
if findItem hendles (hnd = (getHandleByAnim groupNode)) == 0 do
name = groupNode.name ; number = 0 ; append hendles hnd
groupNode = getAllGroupMembers groupNode
groupNode = for o in groupNode collect
if isgrouphead o then o else
o.name = name+sufix
o.name += (formattedPrint (number += 1) format:"0.3d")
dontcollect
if groupNode.count > 0 do for g in groupNode do renameGroupMembers g &hendles sufix
Reply to pixamoon
o_O
Now you see what I talking about :)
Group topics are interesting and mind blowing in the same time :)
Here is the solution.After you run this open Schematic View to see result
hendles = #()
groups = for g in objects where isGroupHead g collect g
fn isGroupHeadMember head node act:off =
while isvalidnode node and isgroupmember node and not (act = (node.parent == head)) do node = node.parent
act
fn getAllGroupMembers head = if isgrouphead head do
for node in (join #() head) where isGroupHeadMember head node collect node
append hendles hnd
o.name = uniquename (name+sufix) ; dontcollect
for g in groups do (renameGroupMembers g &hendles "_Object")
free groups ; free handles
pixamoon
This should make a job. Take a look.
for g in objects where isGroupHead g do (
	i = 1
	for o in g where o != g do (
		no = case of (
			(i < 10):("00" + i as string)
			(i <100):("0" + i as string)
			default:(i as string)
		o.name = g.name + no
		print o.name
		i += 1
Best,
Pixamoon
Thank you !
Still so much to learn :)
And yes, of course to groups inside groups... but it is just simple renaming tool base on group names
simplified code :
	i = 1
		o.name = g.name + (formattedPrint i format:"0.3d")
		i += 1
Reply to pixamoon
pixamoon
how about this ?
To rename all object inside, inside ... groups by main group name
-- firts rename all by group witout numbers
	for o in g do o.name = g.name
-- collect unique names array
uNames = #()
for o in objects where isGroupHead o == false do appendifunique uNames (o.name as name)
uNumbers = #()
for i = 1 to uNames.count do uNumbers[i] = 0
--add numbers to the same names
for o in objects where isGroupHead o == false do (
	if (a = findItem uNames (o.name as name)) > 0 then (
		uNumbers[a]  +=  1
		o.name = o.name + (formattedPrint uNumbers[a] format:"0.3d")
Just quick idea... please test it and let me know how it works.
Best,
Pixamoon
Reply to pixamoon
I will use example of previous mentioned thread by DenisT.
Here you have groups inside group and some of theses are just linked to each other.
f0 = box name:"f0" pos:[80,40,0] wirecolor:orange
in f0 (f1 = box name:"f1" pos:[80,80,40] wirecolor:orange)
in f1 (f2 = box name:"f2" pos:[80,80,0] wirecolor:orange)
c0 = box name:"c0" pos:[40,40,0] wirecolor:orange
c1 = box name:"c1" pos:[40,80,40] wirecolor:orange
c2 = box name:"c2" pos:[40,80,0] wirecolor:orange
b0 = box name:"b0" pos:[40,0,0] wirecolor:orange
b1 = box name:"b1" pos:[80,0,0] wirecolor:orange
b2 = box name:"b2" pos:[40,40,0] wirecolor:green
b3 = box name:"b3" pos:[80,40,0] wirecolor:green
g4 = group #(c1,c2) name:"g4"
g0 = group #(b0,b1) name:"g0"
g4.parent = b0
g1 = group #(b2,b3,g0) name:"g1"
g2 = group #(c0, g1) name:"g2"
in b0 (box name:"d0" pos:[0,0,80] wirecolor:blue)
in g0 (box name:"d1" pos:[0,0,120] wirecolor:blue)
a0 = box name:"a0" pos:[0,40,80]
a1 = box name:"a1" pos:[0,80,80]
g3 = group #(a0,a1) name:"g3"
g3.parent = g2
g5 = group #(f0,f1,f2,g2) name:"g5"
for g in #(g0,g1,g2,g3,g4,g5) do setGroupOpen g on
