rename object name to filename
By kutty · 2009-08-18
hi,
can any body help me out to get this easy task..
select $sphere01
with this script line,, i am able to select with script,, but i want extend this script by making the selected file object with script, to make the selection name to be same as file name. if my file name is testing.max,, i want this sphere01 object in max file to be renamed by testing
can anybody help me... thanking you..
kutty
Hi Kutty,
maxFileName is what you looking for (#step_1):
$.name = maxFileName -- but if the scene not saved (Untitled) maxFileName return empty string
. So, if the scene file name is "test.max", your selected object will be with the same name. But if you want only the name of the scene (without ".max") - #step_2:
$.name = trimRight $.name ".max" -- now your object name is "test"
Or combine code in 1 step only:
$.name = trimRight maxFileName ".max"
fajar
just using Track script , you can find it here, it's cool and have ability to select object with given name too !! you'll gonna love it!
