Remvove item from utilities drop down box
By seggaeman · 2010-12-09
Hi I got a query: how to remove an item from the utilities drop down list box in 3ds max? There is a "close" button to make the rollout disappear but I can't figure how to remove the item from the drop down menu once the custom utility is loaded.
seggaeman
ok in that case I won't worry unduly about it.It's just because if I change the name string associated with a utility I'm creating and run the script again, I get the new string int the drop down menu and the old one stays there. Then if I run the garbage collector in the listener(in an attempt to remove the invalid name) and open the utilities panel, 3ds max has to shut down because of an exception.
btw I'm not a professional artist/programmer I just learnt 3ds max and MAXScript for the sake of game modding. Right now I am writing a plugin to import/export GTA San Andreas models (or rewriting, since there already is already a buggy one that exists but it is encrypted). if anyone is interested in contributing you are welcome :)
Well, no way. It will stay in the list to the end of the session, but why you worry about?
