Removes 2 verticles splines from the multuiple EditableSpline objects
By harumscarum · 2023-07-25
here is have script which do the job to remove 2-vertices splines from the Editable Spline objects, however I'm failed to make it work on multiple EditableSpline objects selected please help
<code>
fn deleteSplinesWithTwoVerts obj =
    if classof obj == Editable_Spline or isKindOf obj SplineShape then
        subObjectLevel = 1 -- switch to spline sub-object level
        for i = obj.numSplines to 1 by -1 do -- Iterate through splines from last to first to avoid reindexing issues when deleting
            if (numKnots obj i) == 2 then
                deleteSpline obj i
        subObjectLevel = 0 -- reset to object level
        messageBox "Please select an EditableSpline object."
-- Execute function
deleteSplinesWithTwoVerts selection[1]
</code>
	function DeleteSplinesWithTwoVerts obj =
		for i = numSplines obj to 1 by -1 where ((numKnots obj i) == 2) do deleteSpline obj i
		updateShape obj
	for o in selection where classof o == line or classOf o == splineShape do DeleteSplinesWithTwoVerts o
