Remove xref, save file, then ADD xref back
By tomastnt · 2014-03-04
Hi dear,
I would like to use this script from: http://www.scriptspot.com/forums/3ds-max/scripts-wanted/disable-xref-sce…, but I need REMOVE xref, save to separate file and then again ADD xref back and save to previous file. Now it is only DISABLING xref. practicaly I would like to create a copy max file where is no xref and name of that file is every time same. I have modified this script, but it is only disabling xref and I don't know how to rewrite it for removing xref. Here is it. Any help will be much much appreciated! I am very easy to write mascript, so be patiant please Thanks Tomas.
if maxFileName != "" then
( -- if the scene saved
local enabledXRefIndex = #()
for i = 1 to xrefs.getXRefFileCount() where ((xrefs.getXRefFile i).disabled == false) do
(xrefs.getXRefFile i).disabled = true -- disable the xref
append enabledXRefIndex i -- store the index of the active xref scenes
filename = (maxFilePath + maxFileName)
noxreffilename = "File_No_Xref.max" as string
--noxref = (maxFilePath + noxreffilename)
saveMaxFile (maxFilePath + noxreffilename)
for i in enabledXRefIndex do (xrefs.getXRefFile i).disabled = false
saveMaxFile filename
) else checkForSave()
Try this:
		local currentXRefScenesIndexArr = #()
		for i = xrefs.getXRefFileCount() to 1 by -1 do
			append currentXRefScenesIndexArr (xrefs.getXRefFile i).filename
			delete (xrefs.getXRefFile i)
		saveMaxFile (maxFilePath + "Interier_No_Xref") useNewFile:false quite:true
		-- reload the deleted xref scenes
		for i in currentXRefScenesIndexArr do
			xrefID = xrefs.addNewXRefFile i
			xrefID.autoupdate = true
			xrefID.hidden = false
			xrefID.boxDisp = true
			xrefID.disabled = false
	else checkForSave()
tomastnt
nope, it is not working. Don't know why. It gets me crazy. It worked yesterday on same scene, now it is not working. Thanks for help.
(xrefs.getXRefFile i).autoupdate = true
(xrefs.getXRefFile i).hidden = false
(xrefs.getXRefFile i).boxDisp = true
for i in currentXRefScenesIndexArr do (xrefs.getXRefFile i).disabled = false
else checkForSave()
tomastnt
loks like I have got it, I have just add:
and works.Thanks.
tomastnt
thanks, works great. Coud you pleas also store the information of Autoupdate and ignoreLights? The other stuff i will add similar to this features. Again thank you. Tomas
Try this:
The name of the new file will be "File_No_Xref.max" and will be saved in the same directory where the original file is.
		saveMaxFile (maxFilePath + "File_No_Xref.max") useNewFile:false quite:true
		for i in currentXRefScenesIndexArr do xrefs.addNewXRefFile i
	else checkForSave()
