I would like to know how I can create a script that specifically deletes a certain object from the scene.
Example: I accidentally select a space warp or particle view or something and I want to be able to click a button that automatically finds particle view and removes it from my scene.
Here's my lousy attempt:
on press return (Particle_View.current!=undefined)
on execute do
if( Particle_View:Particle View.current==undefined ) then true
else Particle_View.current.DeleteSelected()
Comments (7)
the fastest way is:
if (pfs = getclassinstances PF_Source).count > 0 do delete pfs
Are you test your code? if
First "pfs" variable is local to the IF scope and become undefined for the delete ops, so the well known error appear:
But that not is all, try this:
Thanks Anubis, this for loop is way more efficient and get rid of the Array.
the fast way to delete all PF_Source in the scene:
thank you very much guys. I'm going to experiment with these and see if I can't learn something :)
Here is a version which ask for user if he wants to delete the PF_Source with its name in the querybox.
I'm not sureif I understood correctly, but you could loop through each scene object and make an array with only the PF_Source. Then in a for loop you could delete every object in the array. It's not really clean I'm no maxscript pro but this seems to work.
