hi everyone!
This is what I need, please tell me if it's possible or not.
I've orginized all evermotion models into a series of folders.
When I need to merge a model into a scene, I've two option:
- merge the model and copy the relative texture and past it into my project folder, then relink it through the asset browser
- merge the model and relink manually texture till the evermotion folder.
I'd like to avoid to relink texture when I merge an evermotion model into my scene.
I'd like just to merge and render.
So my question is: can I select a series of .max files (3d evermotion model in my case) and make all of them aim toward a common folder for texture? (I mean model of the same volume)
Thank you in advance.
FilePathFinder help you http://3d-kstudio.com/?p=126
Video about Batch mode
Check also new drop and Relink - it will auto-relink paths while merging:
http://www.scriptspot.com/3ds-max/scripts/drop-and-relink
or
http://www.scriptspot.com/3ds-max/scripts/merge-relink
or to re-path whole models library - new tool Library Track/Relink:
http://www.scriptspot.com/3ds-max/scripts/library-track-relink
Cheers,
Pixamoon
use relink bitmap, find it here....
