Please help me how to make that script was interactive in viewport when values are changed in the checkbox. Code create Bevel with radius at the polygon
rollout radius "BEVEL RADIUS"(
spinner rad "Radius " type:#Float range:[0,1000,1.0] fieldWidth: 40 pos:[18,15]
spinner seg "Segments " type: #integer range:[0,1000,1] fieldWidth: 40 pos:[4,45]
checkbox ext "Extrude" checked:false pos:[115,15]
checkbox out "Outline" checked:false pos:[115,45]
groupbox gb5 "Bevel Type" width:100 height:70 pos:[180,5]
radiobuttons rbBevelType labels:#("Group", "Local Normal", "By Polygon") columns:1 pos:[190,20]
button but_radius "Create" pos:[120,80]
on but_radius pressed do undo on(
n=seg.value
r=rad.value
a=90/(n+1) as float
a0=a
b0=0
c0=r
j=0
for i=1 to n+1 do
b=(r*sin a)-b0
b0=r*sin a
c=c0-(r*cos a)
c0=r*cos a
a=a+a0
$.bevelOutline = (if out.checked then 0-c else 0-b)
if ext.checked then $.bevelHeight = (if out.checked then 0+b else 0+c)
else $.bevelHeight = (if out.checked then 0-b else 0-c)
case rbBevelType.state of
1: ($.bevelType = 0 )
2: ($.bevelType = 1 )
3: ($.bevelType = 2 )
$.EditablePoly.buttonOp #Bevel
j=j+1
createDialog radius 290 110
I don't see any problems
It works (MAX 2009).
