redefine variable after layer creation
By cdb · 2018-05-05
hi,
this little script will make a box and look for a "test_layer" to be parented to.
if the layer not exist it will create one, if it exist it whill parent the box to it.
my problem is that if this layer not exist i can't put the object on it after creation if i do not redefine the variable, it actually doesn't read the "lay" variable anymore and print me undefined instead of .
do you have any tips? thanks!
fn boxlayer x y z =
	b= box width:x length:y height:z name:"test_box"
	lay = layermanager.getlayerfromname "test_layer"
	n_lay = layermanager.newlayerfromname "test_layer"
	if lay == undefined do n_lay							---------this looks for "test_layer" and create a new one if needed
--	lay = layermanager.getlayerfromname "test_layer"           	  		---------uncomment this will  make it work, why do i need to redefine the variable?
	if lay != undefined do (lay.addnode b)
boxlayer 100 100 50
pixamoon
This should help:
fn boxlayer x y z =
	local b = box width:x length:y height:z name:"test_box"
	local lay = layermanager.getlayerfromname "test_layer"
	if lay != undefined do lay.addnode b
boxlayer 100 100 50
Best,
Pixamoon
