Hi, I have this script which reads a txt file with xyz positions and a mesh name
How can I add xyz rotations aswell or change this to rotation only.
Sample.txt format
478,733,-46,mesh01
file = memStreamMgr.openFile @"C:\sample.txt"
while NOT file.eos() do
local line = filterString (file.readLine()) ", "
if line.count == 4 AND isValidNode (local obj = getNodeByName line[4]) do
obj.pos = [line[1] as float, line[2] as float, line[3] as float]
memStreamMgr.close file
read pos/rot from a file and apply to listed scene objects
I found a solution elsewhere
(rotate script)(
file = memStreamMgr.openFile @"C:\position.txt"
(position script)
file = memStreamMgr.openFile @"C:\rotation.txt"
obj.rotation = eulerAngles (line[1] as float) (line[2] as float) (line[3] as float)
