Read ASCII string from external file
By seggaeman · 2010-12-15
Hi, I'm working on a model importer/exporter for a game which I am coding in MAXSCRIPT. I'm getting trouble doing the thing I mentioned in the title. Well actually I have written a script that does the job but it is slow & takes almost 5 seconds to find 4 bytes of data in a 220 kb file.
function findstr filename=
fstream= fopen filename "rb"
fseek fstream 0 #seek_end
end= ftell fstream
pos= 4
while (pos <= end) do
fseek fstream pos #seek_end
val= readlong fstream #unsigned
/* 860639043 is the value the "readlong" function gives when the data in question is read */
if (val == 860639043) then exit
pos= pos+1
fseek fstream pos #seek_set
pos= ftell fstream
fclose fstream
return pos
This is a binary file so I can't use skiptostring(I tried it). "Readstring" doesn't work too well either.
this 4s is very inefficient, a small hex editor does this job in no time. Please could I have some feedback on how to write a better script for this job (as well as reading/writing data from/to external files in general?)
Graph
return you can but dont have to use (if you wish to then only at the END of a function)
exit is one of them overhead thingies you really shouldnt use as it kinda shoots hot liquid led into your legs ;)
and you should get used to always defining the scope of your vars, yes even in a function ..where they are local by default
seggaeman
skip 'exit' and 'return'
Thanks that's a nice way of bypassing the exit and return! I think the pointer will have to be readjusted after each "readlong" however otherwise I risk missing the data I am looking for, if it gets split between successive reads.
On I own I managed to speed up the script by using the end of the file as base for the pointer instead of the beginning (the data is always closer to the end in the files I am reading from). I'll rewrite it again now without the "exit" and "return".
veneta
as i know 'exit' slow down a lot ('return' too), try this...
-- if return -1 you'll know that the long is not found
   fstream = fopen filename "rb"
   run = true ; pos = -1
   while (not eof fstream) or (run) do
      if (readlong fstream #unsigned) == 860639043 do
         run = false ; pos = ftell fstream
   fclose fstream ; pos
