Randomize Sliders
By bporter88 · 2012-11-08
Hello, I've created a rollout with several sliders and a couple of buttons. I want To be able to press one of the buttons at the bottom of the rollout and generate a set of random values for the sliders. Is this possible? I've attached my script below to make it easier to see where I've gone wrong......many thanks
rollout slide "Riot Parameters"
slider slide "Political Pressure" range:[1,11,1] type:#integer ticks:10
label lbl "0%"
local lbltext = #("0%", "10%", "20%", "30%", "40%", "50%", "60%", "70%", "80%", "90%", "100%")
on slide changed val do lbl.text = lbltext[val]
slider slide2 "Social Pressure" range:[1,11,1] type:#integer ticks:10
label iki "0%"
local ikitext = #("0%", "10%", "20%", "30%", "40%", "50%", "60%", "70%", "80%", "90%", "100%")
on slide2 changed val do iki.text = ikitext[val]
slider slide3 "Racial Tension" range:[1,11,1] type:#integer ticks:10
label plp "0%"
local plptext = #("0%", "10%", "20%", "30%", "40%", "50%", "60%", "70%", "80%", "90%", "100%")
on slide3 changed val do plp.text = plptext[val]
slider slide4 "Local GDP%" range:[1,11,1] type:#integer ticks:10
label gdp "0%"
local gdptext = #("-5%", "-4%", "-3%", "-2%", "-1%", "0%", "1%", "2%", "3%", "4%", "5%")
on slide4 changed val do gdp.text = gdptext[val]
button GetRandom "Randomise Parameters"
on GetRandom pressed do
button GetRandomWeather "Generate Weather"
on GertRandomWeather pressed do
createdialog slide
try this
slider sld1 "Political Pressure" range:[1,11,1] type:#integer ticks:10
label lbl "0%"
slider sld2 "Social Pressure" range:[1,11,1] type:#integer ticks:10
label iki "0%"
slider sld3 "Racial Tension" range:[1,11,1] type:#integer ticks:10
label plp "0%"
slider sld4 "Local GDP%" range:[1,11,1] type:#integer ticks:10
label gdp "0%"
button GetRandom "Randomise Parameters" width:120
button GetRandomWeather "Generate Weather" width:120
local slidersArr = #(sld1, sld2, sld3, sld4)
local labelsArr = #(lbl, iki, plp, gdp)
on sld1 changed val do lbl.text = lbltext[val]
on sld2 changed val do iki.text = lbltext[val]
on sld3 changed val do plp.text = lbltext[val]
on sld4 changed val do gdp.text = lbltext[val]
for i = 1 to slidersArr.count do
val = random 1 11
slidersArr[i].value = val
labelsArr[i].text = lbltext[val]
createdialog slide
