Radiobuttons going crazy :(
By Mrjacks2o · 2009-11-16
Hi when i add a second line where i put arrows on the script bellow,
the script gives an error, but when everything is on 1 line it works fine other then the scale action that only works on a separate line
i want to add this to the second line under merge -> scale $ [0.90,0.90,0.90]
or is there a way i can put it all in 1 line without getting errors?
thanks in advance...
fn updateButton = (
do_it.text = case copy_type.state of (
1: "Cutter1 "
2: "Cutter2 "
3: "Cutter3 ")
do_it.text
on bt09 pressed do (
copyfn = case copy_type.state of (
1: mergemaxfile "C:\\Program Files\\Autodesk\\3ds Max 2010\\Scripts\\3DJM\\Cutters\\Cutter1.max" #("CutterA") #select #MergeDups <<<<-Problem cant add scale here
2: mergemaxfile "C:\\Program Files\\Autodesk\\3ds Max 2010\\Scripts\\3DJM\\Cutters\\Cutter2.max" #("CutterB") #select #MergeDups
3: mergemaxfile "C:\\Program Files\\Autodesk\\3ds Max 2010\\Scripts\\3DJM\\Cutters\\Cutter3.max" #("CutterC") #select #MergeDups
Marco Brunetta
Just open a parenthesis after the "1:" so that you can run several lines of code.
  CASE x OF
    1:
      --do something
    2:
      --do something else
    3: --do another thing
