Radio Buttons - Spacing
By JokerMartini · 2010-08-29
I was wondering if you knew a way to control the vertical spacing of radio buttons in a single column?
I've noticed in some of the max UI for instance in the Preferences Rendering tab that in the Field Order the vertical spacing is larger than other parts of the UI using radio buttons.
Help would be great. Thanks
John Martini
JokerMartini
try this instead
try(destroyDialog ::rlRB)catch()
rollout rlRB "Vertical"
fn fnOpt idx= (
range = #(rlRB.rbA, rlRB.rbB, rlRB.rbC)
for o in range where idx != o do
o.state = 0
label lbTypes "Types:" pos:[10,10]
radiobuttons rbA "" labels:#("A") pos:[60,10] default:1
radiobuttons rbB "" labels:#("B") pos:[60,40] default:0
radiobuttons rbC "" labels:#("C") pos:[60,90] default:0
on rbA changed state do (fnOpt rlRB.rbA)
on rbB changed state do (fnOpt rlRB.rbB)
on rbC changed state do (fnOpt rlRB.rbC)
createDialog rlRB 150 150
Reply to JokerMartini
Very nice, John.
Now it's works.
I avoid to use radiobuttons ctrl, instead,
I use checkboxes that mimic the behavior of radiobuttons.
Anyway, thanks for sharing this interesting solution.
JokerMartini
SOLUTION!
local range = #(rlRB.rbA, rlRB.rbB, rlRB.rbC)
fn fnOpt idx= (
o.state = 0
I don't know but something is wrong.
When i run tour code max throw this error:
-- Error occurred in anonymous codeblock; filename: D:\...; position: 549; line: 22
-- Unknown property: "rbA" in undefined
I also wondered can I do this. Definitely no such feature available. I suspect that its possible (because we can set the state of radio buttons to 0 to deselect) to accomplish this with multiple rbuttons using separate rbutton for each label, but so far I have not tested it.
