Hi !
I need to create a question with 2 choice for example :
"What do you want ?"
- Do (choice 1)
- I don't want (choice 2)
- Cancel
when choice 1 is pressed do ...
when choice 2 is pressed do ...
when cancel is pressed do ...
Stop the script
How translate that in Maxscript ?
Comments (8)
For more info read this topic
Can we create a answer without " yesNoCancelBox " ?
without YesNoCancelBox
rollout bgaRoll "• • •"
edittext sufix "Sufix Pattern:" text:"2_"
button btn_delchilds "Delete childrens" pos:[5,25] width:100 height:20
button btn_delparents "Delete parents" pos:[110,25] width:100 height:20
on btn_delchilds pressed do
delete (for o in objects where matchPattern o.name pattern:("*"+sufix.text+"*") collect o)
on btn_delparents pressed do
delete (for o in objects where matchPattern o.name pattern:("*"+sufix.text+"*") and o.parent != undefined collect o.parent)
createDialog bgaRoll 220 50 style:#(#style_titlebar, #style_sysmenu, #style_toolwindow)
Thanks You !!!
Thanks you veru mush barigazy :D
I'll to learn Max script because I'm bad at it today , I know do a little script with step but never a complete script :(
Have a nice day ! :)
Regards
Kasimashi
Just start with basic stuff, see this training if you already not http://vimeo.com/album/1514565 , read mxs help and ask forum if you have problem with you code. Is that simple or not? :)
Cheers!
Branko
:) funny answer
if queryBox "Do you want to create a box" beep:false then Box() else print "No Box for you :)"
:p
Thanks but In fact I need :
A question say :
"Do you want a destroy or standart batiment?"
- Standard (choice 1)
- Destroy (choice 2)
- Cancel
if choice 1 is pressed do :
select (for o in objects where matchPattern o.name pattern:"*2_*" collect o) delete $
if choice 2 is pressed do :
select Parent of the children are exist and delete them.
like this : http://img15.hostingpics.net/pics/142816parentofchildren.png
if cancel is pressed :
stop the script
