Pulldown lists not working in 2014?
By reapinwombat · 2013-12-05
Hello all,
I have a script in MAX 2013 that uses a pulldown list to set the current animation range. In max 2014 this script is partially broken. The codeblock for the pulldown list is not being run as if the UI is not registering the change in list item. Is this a known issue and is there a work around?
I am using:
on ddl_range selected itm do (
  messageBox("wee")
ddl_range is defined earlier:
dropdownlist ddl_range items:#() height:55 width:200 pos:[23,0] --fieldHeight:44
Thanks!
-Greg
dimwalker
I know what you did last summer, reapinwombat ;)
rollout test "test"(
	button bt_huh "?" across:3
	button bt_reg "+"
	button bt_unreg "-"
	dropdownlist ddl_test items:#("1", "2", "3")
	on ddl_test selected i do (
		format "You selected %\n" i
	on bt_reg pressed do	(
		cui.RegisterDialogBar test
		cui.DockDialogBar test #cui_dock_bottom
	on bt_unreg pressed do	(
		try(cui.UnRegisterDialogBar test)catch()
	on bt_huh pressed do	(
		format "% is selected\n" test.ddl_test.selected
createdialog test
Run the script and try changing value in dropdownlist it should spam your choice in listener. Press "?" - it will show current selection. This is how it is supposed to work.
Now press "+" which will register and dock this rollout.
Try changing selection in dropdownlist. After registering the rollout it doesn't generate any events and stops the "You selected x" spamming.
"?" button shows last choice before registering and that value doesn't change no matter what I do.
That's it. Rollout is permanently broken now. Even if I unregister it(press "-") it still doesn't show correct selection.
Can someone please help?
max 2014 SP5
reapinwombat
docked vs undocked...
So this code, when commented, causes the rollout to float--and then it works.
cui.RegisterDialogBar timerange style:#(#cui_dock_bottom,#cui_dock_top, #cui_floatable, #style_toolwindow)
cui.DockDialogBar timerange #cui_dock_bottom
Why does this no longer function docked in 2014 or how can I make it behave itself.
Thanks!
-Greg
br0t
working for me without any problems. you might have to post more code
