1. I made some batch script to load file and export it to fbx file, the problem is i made progressbar (max progressbar (via progressStart "my batch") which works fine if I loading file only, but its completely overided by fbx file exporter progress bar if I add export script, can I made the progress bar of fbx bar didnt appear or overided progress bar ?
2. second I try to make dialog that contain progress bar (not max progress bar but dialog progress bar), but it was always got blinked after reseting the max file, can i make my dialog not blinked when the max file reseted and opened ?
3. 3rd question, simply but still cant find the answer through the net tho, how to cancel the batch process, I know little bit bout exit command but i want to triger it by button , how to do that ? somthing like
on btn_cansel do (command to cancel the batch procces)this is for all I know
for i=1 to mf.count do
mf[i]
if keyboard.escPressed then
exit
---command to exporting file
Thanks for the attention
Best regard
fajar
Might be tricky to override the existing progress bar. You could possibly create a dotNet one which would be displayed overtop the max one.
