Hello, I'm starting to program in MaxScript and I'm making a script to automate the mirror morphing, I made it in 2 parts, 2 buttons, the first part it's ok, but the second one does not work when I press the button but when I run it directly from the script it works as it should. I need ideas, thanks for your help!
rollout Carol_MirrorMorphing "Carol Morphing V2.1" height:155 width:232
fn foo_filter obj = matchPattern obj.name pattern:"Base*"
fn ex_filter obj2 = matchPattern obj2.name pattern:"*"
label titulo "MIRROR MORPH v 2.1"
label titulo2 ""
pickbutton BaseMorph1 "Select BaseMorph" width:140 filter:foo_filter
pickbutton Expresion1 "Select Morph" width:140 filter:ex_filter
button crear "1st Part"
button seguir "2nd Part"
label titulo3 ""
label label1 "© ESARTE Digital | Ana Carolina Escobar | 2012 " width:232
on BaseMorph1 picked obj do
if obj != undefined do
BaseMorph1.text = obj.name
Global BM = obj
on Expresion1 picked obj2 do
if obj2 != undefined do
Expresion1.text = obj2.name
Global Exp_1 = obj2
on crear pressed do
if BaseMorph1.text == "Select BaseMorph" or Expresion1.text == "Select Morph" then
messagebox "No has seleccionado alguno de los elementos requeridos"
copy BM isSelected:on
b = BM.pos
$.pos = b + [90,0,0]
$.name = "basemorphcopy"
CopyPos = $.pos
deselect $
copy Exp_1 isSelected:on
$.position = $basemorphcopy.pos
$.name = "expresioncopy"
deselect $
Global MyMorpher = Morpher Autoload_of_targets:1
addmodifier $expresioncopy MyMorpher
WM3_MC_BuildFromNode MyMorpher 1 BM
WM3_MC_SetValue MyMorpher 1 100.0
/*mat = $expresioncopy.transform
mat.row1 = -mat.row1
$expresioncopy.transform = mat*/
/*select $expresioncopy
modPanel.addModToSelection (mirror ()) ui:on
maxOps.CollapseNode $expresioncopy off
deselect $*/
messagebox "Mirror en X"
on seguir pressed do
MySkWrap = Skin_Wrap Autoload_of_targets:1
addmodifier $basemorphcopy MySkWrap
MySkWrap.Distance = 0.1
Lista = #($expresioncopy)
MySkWrap.meshlist = Lista
WM3_MC_SetValue MyMorpher 1 0.0
maxOps.CollapseNode $basemorphcopy off
delete $expresioncopy
select $basemorphcopy
$.position = Exp_1.pos + [50,0,0]
$.name = "MirrorMorphExp_001"
macroScript Carol_MirrorMorphing_A
category:"MyOwnScripts"
tooltip:"Realizar Mirror Morphing de derecha a izquierda y viceversa"
Createdialog Carol_MirrorMorphing
