Problem with selection
By titane357 · 2019-07-31
Hi
I made a little script to random in z selected edges. ( like random boards )
It works fine but after using it I can't select another edges and run script as script use selection done before running script.
a = $
selE = a.EditablePoly.getSelection #Edge as array
	try destroyDialog rlslice catch()
	global rlslice = rollout rlslice "RDM edges on Z"
		button butconnect "GO" pos:[2,2]
		spinner spX "MIN " width:90 range:[-10000,10000,-0.5] type:#float pos:[55,5]
		spinner spY "MAX " width:90 range:[-10000,10000,0.5] type:#float pos:[55,25]
			on butconnect pressed do
			undo on
				for ss in selE do
				pp = polyop.getEdgeVerts a ss as array
				ppx1 = a.verts[pp[1]].pos.z
				ppz2 = a.verts[pp[2]].pos.z
				ppx3 = ppx1 + random  spx.value spy.value
				polyOp.setVert a pp[1]  [  a.verts[pp[1]].pos.x , a.verts[pp[1]].pos.y , ppx3]
				polyOp.setVert a pp[2]  [  a.verts[pp[2]].pos.x , a.verts[pp[2]].pos.y , ppx3]
createDialog rlslice 160 50
I made a button to get selection to "reset" selection.
But it don't work... anybody can help ?
It is certainly a "$", "selection","$selection","GetCurrentSelection",.... problem ???
	global rlslice = rollout rlslice "RDM edges on Y"
		button butget "get"
		spinner spX "MIN " width:90 range:[-10000,10000,0] type:#float
		spinner spY "MAX " width:90 range:[-10000,10000,0] type:#float
		on butget pressed do
		a=$
			undo on
				for ss in selE do
createDialog rlslice 160 150
titane357
my script :move edge
my script :
move edge randomly on z
move each vextex's edge randomly on z
---corrected by MIAUU
		local a = undefined
		local selE = undefined
		spinner spY "VAL " range:[-10000,10000,.1] type:#float width:75  offset:[-55,10]
		spinner spYY "" range:[-10000,10000,.01] type:#float width:70  offset:[10,-21]
		button butconnect "GO" width:90  offset:[0,20]
			undo on
 				a=$
				for ss in selE do
				ppx2 = a.verts[pp[2]].pos.z
				RDMMAX = random (-spY.value) (spY.value)
				ppx11 = ppx1 + ( RDMMAX ) + (random (-spYY.value) (spYY.value))
				ppx22 = ppx2 + ( RDMMAX ) + (random (-spYY.value) (spYY.value))
				polyOp.setVert a pp[1]  [  a.verts[pp[1]].pos.x , a.verts[pp[1]].pos.y , ppx11]
				polyOp.setVert a pp[2]  [  a.verts[pp[2]].pos.x , a.verts[pp[2]].pos.y , ppx22]
createDialog rlslice 160 100
Reply to titane357
To make it a little bit faster move the polyop.getEdgeVerts and polyop.setVert outside of the
and make them local variables to the rollout.
Panteleev Sergey
it seems like you overcomplicate things without a reason
move $.selectedEdges [0,0,1]  -- for Editable Poly
$.modifiers[#Edit_Poly].MoveSelection [0,0,1] -- for Edit Poly
Reply to Panteleev Sergey
titane357
Hi jahman ,
yes perhaps,but I have in mind the possibility ( in futur ) to move randomly the vertex of same edge. :-)
			if selection.count == 1 do
				if classOf (curO = selection[1]) == Editable_Poly do
					selEdgesBA = polyop.getEdgeSelection curO
					undo on
						for ss in selEdgesBA do
							pp = polyop.getEdgeVerts curO ss
							ppx1 = curO.verts[pp[1]].pos.z
							ppz2 = curO.verts[pp[2]].pos.z
							polyOp.setVert curO pp[1]  [  curO.verts[pp[1]].pos.x , curO.verts[pp[1]].pos.y , ppx3]
							polyOp.setVert curO pp[2]  [  curO.verts[pp[2]].pos.x , curO.verts[pp[2]].pos.y , ppx3]
Do you see why your script is not working?
You get the selected edges when you run the script and the roolout is created. After that every time when you press the GO button it will work with edges, selected when the script was executed.
The second version not works because the variables "a" and "selE" are local for the "GET" button and are not accessable by the GO button. This will solve the problem:
		local a = undefined
		button butget "get"
		a=$
			undo on
				for ss in selE do
Reply to miauu
titane357
Hi, Miauu
Thanks again and again...
I knew that the first version have the problem, it is why I did the second one.
I undestand now the need to define variables locally for the whole script.
It wasn't so obvious to me that my variables was just defined inside the"on get pressed"
