Problem with scale controller expression
By Tialkannos · 2010-05-27
Why this script does not work?
for i in selection do
if classOf i == BoneGeometry then
b = box length:i.height \
width:i.length \
height:i.width \
pivot:[-i.length/2, 0, i.width/2]
b.transform = i.transform
b.parent = i
b.scale.controller = scale_script()
b.scale.controller.script = "$.parent.stretchTM.scale"
--above is the line with problem
What am I doing wrong?
And thanks for any help.
lutteral
That's correct, you should avoid using the "$" sign in the script part of a scripted controller. Instead you should use the .addNode method (check the maxscript help on script controllers) to add a local variable for the controller and then assign that on the script string. somewhat like this (not tested, by the way)
b.scale.controller.addNode "obj" <put your node here>
b.scale.script = "obj.parent.stretchTM.scale"
This will throw an error if the node doesn't have a parent, so you should add some extra checking in your script before assigning the script controller
This sign "$" means the object need to be selected, and if more than one object is selected also will not works, so shortly use the object name instead, i.e.:
-- replace this line...
-- with this one...
b.scale.controller.script = "$"+b.name+".parent.stretchTM.scale"
