Problem Running Script
By andrej · 2016-01-21
Dood day.
I can't run the script use MAXScript/Run Script command
System massege
MAXScript FileIn Exception
-- Type error: Call needs function or class, got: undefined
ОК
but the script narmal run use Evalute All command, from MAXScript Editor window...
Why ????
andrej
I found the cause of the error. You need to remove all commented lines from our script.
