Problem in Constrain scripting
By jaber · 2014-01-28
Hi:
I try to write position constrain by script,we have a Box001 and a Point001
the script is this
b= $Box001
ptHelper = $Point001
b.position.controller = position_list()
b.position.controller.available.controller = position_constraint()
b.position.controller.setActive 2
b.position.controller.setName 2 "Constraint: Position"
b.position.controller["Constraint__Position"].appendTarget ptHelper 100
this work fine but i need, instead of (b)for example adding pick button to take
box001 then refer (b) to that value would anyone help please.
jaber
Hi
Thanks so much,i am new with this site,it was the first time sb help this quick .thanks again. it was exactly what i was looking for to write "stretchy bone".
jaber
Thanks alot
Hi
Thanks so much it was exactlly what i was looking for to write "stretchy bone".
Use the buttons to pick the objects. The object picked with "Pick object 01" will be constrained to the object picked with "Pick object 02" button.
	global rol_
	try(destroyDialog rol_)catch()
	rollout rol_ ""
		local obj01 = undefined
		local obj02 = undefined
		pickbutton btn_01 "Pick object 01"
		pickbutton btn_02 "Pick object 02"
		button btn_start "Add constrain"
		on btn_01 picked obj do obj01 = obj
		on btn_02 picked obj do obj02 = obj
		on btn_start pressed do
			obj01.position.controller = position_list()
			obj01.position.controller.available.controller = position_constraint()
			obj01.position.controller.setActive 2
			obj01.position.controller.setName 2 "Constraint: Position"
			obj01.position.controller["Constraint__Position"].appendTarget obj02 100
	createdialog rol_
