Pressing keys in the listener
By TsveTan · 2012-02-08
I am novice to the site and to maxscript.
I am using the pickobject() fn in a dotnet checkbox eventhandler function.
The problem is it works fine, if you select the picked object and not cancel the action.
If i know how to press the "escape" key in the listener i will be able to stop the function. I tried to use the "sendkeys" class with the "sendwait" method, but it only works as input in the listener.
Is there a way to press a key in a dialog (maxscript listener) by its HWND from a script.
Tsvetan
Comments (7)
Ewok
Hi guys,
I just tried the code by anubis in order to print an "E" in the MAXScriptListener by sending the "{E}" key to it.
But, it doens't work. I only get this result:
true
MCR_SendKeys()
undefined
Just in case the modified code looks like that:
actionMan.executeAction 0 "40472" -- Open the Listener
fn MCR_SendKeys sysKey =
	local WM_ACTIVATE = 0x6
	local SendKeys = dotNetClass "System.Windows.Forms.SendKeys"
	ListenerHWND = (windows.getChildHWND 0 "MAXScript Listener")[1]
	MacroChHWND = (windows.getChildrenHWND ListenerHWND)[2][1]
	Windows.sendMessage MacroChHWND WM_ACTIVATE MacroChHWND 0
	SendKeys.SendWait sysKey
MCR_SendKeys "{E}" -- send Escape key to MacroRecorder sub-window
Does anyone konw what's wrong?
I also don't understand what
stands for.
TsveTan
Yes of course, it was helpful. I searched 2-3 days on the web for a way.
I believe we will meet again.
Thank you (Blagodarq)
welcome ;)
I think I forgot to say Welcome to the site and scripting, so I do it right now :)
Glad to know as well that I was helpful with something.
Anubis
TsveTan
Many Thanks, colleagues
I write down the function body in my case to be much clear, if someone is searching on the web for a similar solution.
The "MCR_SendKeys" function is exactly what I am looking for.
global SendKeys = dotNetClass "System.Windows.Forms.SendKeys"
MacroChHWND = (windows.getChildrenHWND ListenerHWND)[1][1]
fn checkedbtn o a =
if o.checked == true then
o.backcolor = o.backcolor.gold
obj = pickobject filter:shapeFilt forceListenerFocus:false
if obj != #escape and obj != undefined then
o.text = obj.name
o.checked = false
MCR_SendKeys "{Escape}" -- send Escape key to the Listener sub-window
o.backcolor = o.backcolor.azure
dotnet.addEventHandler checkBox0 "checkedChanged" checkedbtn
pickObject prompt:"..." ?
Maybe you use the optional #prompt argument with pickObject(), which popup the Listener?
Its not very likeable option to me.
Here is a function anyway (right copy from my archive) for sending keys to the MacroRecorder sub-window (the pink area in the Listener dialog), but you can modify it to send keys to the main (white area) sub-window. If so, change the [2][1] in line "MacroChHWND = ..." to [1][1] (first sub-window).
MCR_SendKeys "{ESC}" -- send Escape key to MacroRecorder sub-window
I hope this helps
Jos Balcaen
you can check if the obj is undefined.
pickobject will return undefined when the action is cancelled.
Can't help you with the keys..
obj = pickobject()
if obj != undefined then
  --uncheck checkbox
