I've a simple question.
I would like to simply press a button. But something is going wrong.
In my example I try to press the "Select and Move" button by using this line of code:
UIAccessor.PressButtonByName 67616 "Select and Move"As you can see I used the:
Dialog Window Handle: 67616But the MAXScriptListner shows a
false message for it.
Does anybody know what is wrong?
Same here
As "Press Button by Script"... did you find a solution?
The solution is to use UIAccessors and DialogMonitorOps.
Yes I know...
...but I'm quite a noob in scripting.
So i tried to adjust Ewok script (http://www.scriptspot.com/forums/3ds-max/general-scripting/press-button-…) to my needs.
But there is someting wrong because I got no error, the listener returns "OK 66822P 66822P 198868P 198868P" and the command panel switch to hierarchy mode, but nothing else happened.
So where the problem is?
I also tried other solutions here
http://www.scriptspot.com/forums/3ds-max/general-scripting/interactive-i…
but with no luck...
why don't you just use max
Hi Jos,it's just an example
Hi Jos,
it's just an example to keep the topic as general as possible. :)
In reality I would like to press the "Match IK and FK" button of the CAT menu in the Motion panel. I would like to press this button because I can't find any command for it.
