Pre Render Note Track Cleaner
By CGough88 · 2016-01-28
Hi all,
I've had the note tracks issue for a while and know how to clean it with this handy script
t=trackviewnodes;n=t[#Max_MotionClip_Manager];deleteTrackViewController t n.controller
t=trackviewnodes;n=t[#Retimer_Manager];deleteTrackViewController t n.controller
t=trackviewnodes;n=t[#Anim_Layer_Control_Manager];deleteTrackViewController t n.controller
But I've been trying to make a startup script that will run this cleaner before every render, the reason being that merging items into an "infected" scene will bring the note tracks over and it's not easy opening the thousands of furniture scenes I have and cleaning them one by one.
I have the script below so far but often I will get the error -- Unknown property: "controller" in undefined and so forth.
I'm rather lost as I don't do that much scripting at all, any help would make me a very happy chappie.
If it's easier to make this a #PostOpenProcess so it runs every time a scene is opened then that would be fine too.
Many thanks for reading if you got this far.
callbacks.removescripts id:#Extra_Clean
gc()
callbacks.addscript #preRender txt id:#Extra_Clean
gc()
callbacks.addscript #postRender txt id:#Extra_Clean
CGough88
Hi
Just to say that there was a "fix" for this, using a script I blatantly stole from a post Anubis made the cleaner script was made as a macro.
macroscript EXTRA_CLEAN category: "CLEAN"
try
(t=trackviewnodes;n=t[#Max_MotionClip_Manager];deleteTrackViewController t n.controller
catch
print "CLEAN"
And then a startup script (from Anubis) was set up to run the macro before every save and after every merge.
callbacks.removeScripts id:#Auto_Clean
fncb_code = "macros.run \"CLEAN\" \"Extra_Clean\""
callbacks.addScript #filePreSave fncb_code id:#Auto_Clean
callbacks.addScript #filePostMerge fncb_code id:#Auto_Clean
Try to put each:
n=t..........
in try()catch(). It is not a good pratise, but you can see if this works or not.
