Hi everybody!
playing little bit with scripts for rendering process... I do not understand the syntax, how to set the Pre-Render and Post-Render script files to "Render Setup Dialog" by scipt.
Help says:
preRendScript (system String): ""
Get/set the file name of the Pre-Render script.
I couldn't find how to load any file. Could somebody post some example, please?
Thanks a lot
Yes, this is really badly explained in the MXS Reference.
Also if do this test:
You will find a hidden function localPreRendScript which is not described in the Reference :> So, if your pre-render is saved in "C:\test.ms", there is an example usage:
