I have a macros script which creates a dialog at position 0 0 after running it.
I'm searching for a way to set the position of that macroscript to 100 100 from another script. So it overrides the position of the macroscript because i can't adjust that (due to others who work with it)
Thank you :-)
This is the call to the macroscript:
macros.run "bf tools" "bfWorkflow"
it would be better to rewrite the hardcoded part of the macro to use user local settings
otherwise use SetDialogPos
Right I understand. I would rather change it in the macro but i'm not allowed to change the position as others in my company are used to it like that, while I like to change the position just for myself.
So how would this script look like using SetDialogPos in regard to my macroscript.
--this macroscript is loaded from from a network toolbar.
SetDialogPos 100 400
Not sure how to use the to be honest.
something like this
SetDialogPos <variable that holds rollout> [ x_coord, y_coord ]
for this example it would be
SetDialogPos MyRoll [ 100, 100 ]
