I have a dialog pop up that says "Load or Cancel"
Is there a way to make it so the user can not do anything else in max until they choose Load or Cancel"
Somehow locking everything in max. Similar to when error messages pop up in max.
Popup Dialog
By JokerMartini · 2010-11-09
Nice
Hey thanks a ton Anubis. I tried to search for this in the help. I was searching for the wrong key words.
Thanks again.
set modal to true
yes, you can, set modal property to true in the CreateDialog,
some example w`d like:
Quote from the help:
"When the optional modal:<boolean> keyword is set to true, the dialog ignores all user interactions except those within the dialog."
cheers
