hello all
i'm looking for a hint because im pretty clueless right now.
I often merge max file from a bank we have at work and i'm looking for a way to fasten the process.
My biggest problem now is How to populate the array from a DropDownList with file from a choose path.
from my knowledge Dropdownlist use item:#() to fill the list right??
i found about filestream or something like this while skimming the help but man! i need to get to the evidence. i'm such a noob.. better everyday but still a n00b :D
i attached a copy of my .MCR if anyone what to take a look.
btw if anyone wonder the scrip was started in visual maxscript and not yet cleaned.
any help is appreciated
DavidB
--Pdesign_Bank.mcr
--tester avec max 9
Macroscript PDesign_Bank category:"PDesign"
--global
global bank_rollout
global bank_floater
global objname
--global
--include
--variable
bank_Dir_path = undefined
arr_bankobject = #()
--function
fn fill_objectbank =
--arr_bankobject = #()
for i = 1 to arr_bankobject.count do
objname = arr_bankobject[i].filename
--script
rollout bank_rollout " Bank"
button btn_bank_Dir "Path" align:#left across:2 -- pos:[10,30]
edittext etxt_filePath fieldWidth:130 align:#left offset:[-45,0] text:"undefined"
on btn_bank_dir pressed do
bank_Dir_path = getsavepath()
etxt_filepath.text = (bank_Dir_path as string)
on etxt_filepath entered text do
if etxt_filepath.text == "undefined" then etxt_filepath = undefined
else bank_Dir_path = etxt_filepath.text
dropDownList ddlist_objectList "Object List" items:#((objname as string)) pos:[11,35] width:180 height:40
on ddl_objectlist selected do
button merge_obj "merge" pos:[8,80] width:192 height:40
checkbox chbx_rescaleObj "Rescale" pos:[46,125]
label lbl_objPreview "Preview" align:#left
bitmap bmp_objPreview "preview" pos:[16,160] width:184 height:144
groupBox grp2 "Creator Info" pos:[8,315] width:203 height:72
label lbl1 "David Bordeleau" pos:[64,312] width:80 height:15
label lbl2 "silicium_vitae@sympatico.ca" pos:[40,344] width:148 height:19
label lbl3 "25.08.2007" pos:[80,328] width:48 height:16
if bank_floater != undefined then closerolloutfloater bank_floater
bank_floater = newrolloutfloater "presentation Design bank" 216 420
addrollout bank_rollout bank_floater
