polyop method and subobject INDEX
By Maxime · 2019-05-07
Hello there,
I am feeling pretty stupid but I can't get how to find/use index of subobject with polyop method.
They talk about vertexlist/edgelist and facelist but I can't do many things with that (if I print it I just see #{} ). For example, if I want to get the difference between two face's selection or so I need more info than just an empty {}.
What I want actually is an array of my subobject selection that way I could store it. I tried with bitarray instead of array but no more success.
Is it possible to get something like a real array?
Actually I have many further questions but I always try to find it by myself and "google" ^^ but I am pretty sure I can't do anything if I don't fix this issue.
Thank you
Create a teapot(for example), convert it to editable poly. Go to vertex subobject level and select some vertices. Then, while the teapot is selected, execute this
vertListBA = polyop.getVertSelection selection[1]
In the MaxScript Listener will be printed the bitarray that holds the indices of the selected verts. Something like this:
#{90, 334, 338..339, 341..344, 347..349, 353..354, 359, 364, 370..401}
Now those indices are stored in the vertListBA variable. If you want those indices to be stored in array then use this:
vertListBA = (polyop.getVertSelection selection[1]) as array
and if the same verts are selected you will see this:
#(90, 334, 338, 339, 341, 342, 343, 344, 347, 348, 349, 353, 354, 359, 364, 370, 371, 372, 373, 374, ...)
If you want to get the difference between two face's selection:
--select some faces and run this
face01BA = polyop.getFaceSelection selection[1]
--select some other faces
face02BA = polyop.getFaceSelection selection[1]
--now you can use those two bitarrays to find the:
-- difference
face02BA - face01BA
-- intersection
face02BA * face01BA
-- to union the two arays and only the unique indices to remain in the resulting array
face02BA + face01BA
Reply to miauu
Maxime
Hi miauu,
sorry for the delay, I though I would get notification when somebody would reply but it don't.
Thanks for the explanation anyway, I have recently start to better understand how works bitarray compare to array. Still need to practice anyway, seems it's the best way to learn :)
