here i had useful script to set render output filename directly from toolbar, but it is working only for PSD files. could anyone correct this script in order to set *.exr - V-Ray raw image file
<code>rollout psdmRoll "" width:320 height:34
fn get_psdm_index = (
local eff_index
for eff_index = 1 to numEffects do(
eff = getEffect eff_index
if (classOf(eff) == psd_manager) then return eff_index
return undefined
)--fn get_psdm_index
fn get_psdm_filename = (
local psdm_index = get_psdm_index()
if (psdm_index!=undefined) then return (getEffect psdm_index).filename
else return ""
)--fn get_psdm_filename
fn Set_psdm_filename fname = (
if (psdm_index!=undefined) then (getEffect psdm_index).filename = fname
)--fn Set_psdm_filename
fn Update = (
--print "Update"
psdmRoll.edt1.text = get_psdm_filename()
)--fn Update
button btn1 "psd" pos:[0,2] width:32 height:30 across:2
edittext edt1 "" pos:[32,4] width:264 height:19
on psdmRoll open do(
Update()
callbacks.addScript #FilePostOpen "psdmRoll.Update()" id:#psdm_postOpen
on psdmRoll close do(
callbacks.removeScripts #FilePostOpen id:#psdm_postOpen
on btn1 pressed do(
local fname = getSaveFileName caption:"Save Photoshop Document As" filename:edt1.text types:"PSD(*.psd)|*.psd"
if (fname != undefined) then (
edt1.text = fname
on edt1 entered text do(
Set_psdm_filename text
)--rollout psdmRoll
CreateDialog psdmRoll
cui.RegisterDialogBar psdmRoll
cui.DockDialogBar psdmRoll #cui_dock_top
</code>
Who wrote this 'useful' script? Using
is a bad idea in this case, use
instead.
sets savepath..
I do not understand exactly what you want, but maybe this is usefull..
thank you very much! in general it is working now. just put it in scripts/startup folder
and i adopted it to bottom bar (borderless toolbar) and for V-Ray raw image file output in EXR file.
and simple code for harumscarum.ini
the only option i missing is Update. i mean when you load file SavePath script may show path from V-Ray raw image file output
thank you, Anubis
i will try to correct this script according your advice
