Hello,
For a long time now i trying to find answer to a problem,
TASK : Place a Maxform (dotnet maxform) at the bottom of the active viewport.
PROBLEM : i am not finding a way to get and convert the X Y of viewport to the screen space.
Can anyone please help me out with this.
Here is a link to what i want to achieve
http://www.paulneale.com/tutorials/dotNet/form/index.htm#settingProperti…
Comments (11)
You should be able to work out the rest, here is how to get the dimensions and position of the active viewport:
thanx
works perfect! Guess it's not possible to change the position of a rollout? (if the active viewport is changed)
It's possible why not.
This topic is useful for all question related to current thread.
SetDialogPos!
omg I overlooked the SetDialogPos function. I need some sleep.. Works now for a simple max rollout. Trying to solve the dotnet one.
Can figure it out the achieve his transparent effect so that the controls are visible but the forms not.
use form.opacity propertie.(range from 0 to 1)
if I use the form.opacity = 0 the complete form is gone inclusive the controls. But found he solution!
with the maxform you'll get a standard gray backgroundcolor.
with this code you have have controls without form
barigazy, thanx for the help!
Use float value for opacity propertie 0.1, 0.2 etc.
I send you a mail.
What do you think about that look.
omg! thats totaly creasy! looking out for the release!
Thanks Swordslayer for the replay
That helped me a lot, finally i can move on. :)
Anyone? I'd like to know the answer too.
answer to what???
hello jos,
answer to what ???
