pick object problem
By dussla · 2012-08-31
i have selection before
i would like to make new selection
so i use pickobject count:#multiple
but that didn;t work
is there my fault ?
dussla
i found thist ,but that didn;t not work in max9
rollout myRol "Trying to select multiple objects" width:164 height:45
button myButton "Click me" pos:[13,9] width:135 height:25
on myButton pressed do (
local objs = #()
objs = pickobject count:#multiple
messagebox ("Result: " + objs as string)
try (destroydialog myRol) catch()
createdialog myRol
dussla
thank you speed answer
always thank you for speed answer
i will try~
Willian Kim
run "a = pickObject count:#multiple" in listener... and select with mouse objects that be a array... and click enter ...
"a" array is create with objects selects...
could understand?
Reply to Willian Kim
dussla
i tried ,but there is problem
i run that code in listener
that is good
but i have to use code in ms script file
i made selet.ms with that code
that didn't work
what problem?
Reply to dussla
Willian Kim
can you post the script or part of it to understand?
