having problems with this script
I want cPath to = the selected shape that pickbutton gets the name of
macroScript JM2010TL tooltip:"JM2010TL" Category:"Scripts" Icon:#("JM2010TL",1)
JM2010TL_float = NewRolloutFloater "3D Rail Max" 230 247
fn fn_bs_img str1 = (#(getdir #scripts+"\3DRM\\"+str1 , undefined, 1, 1, 1, 1, 1))
rollout MicroPave_roll "Ring Size"
pickbutton pck_test ">>Pick An Object" tooltip:"Pick A Scene Object..."
button OP2 "Insert" pos: [10,10] width:50 height:21
on pck_test picked obj do
pck_test.text = obj.name
On OP2 pressed do
cPath = $Circle001
cpath.rotation = quat 0 0 -0.707107 0.707107
cDum = $Group001
cCon = Path_Constraint follow:true bank:true
cDum.pos.controller = cCon
cDum.pos.controller.path = cPath
addRollout MicroPave_roll JM2010TL_float rolledUp:false
so you should use cPath =
so you should use
It Worked!!!
Thanks allot it Worked!!!!
Now is there a way to add to this script instead of CDum=$Group001 i want it to = a selected object or selected group is it possible to do this? thanks in advance :)
CDum = $ or CDum =
not sure if its this is what you asked
Nice!! thanks your a big help bro!!!
