I'm trying to find a way to orient a facing card in a particle system to be always facing camera but be orientated to be parallel to the camera as well. So the bottom and top edge of the facing card matches that of the camera.
Particle Orientation
By JokerMartini · 2012-05-22
Hope this help
pfSys = ($PF_Source_001)
count = pfSys.NumParticles()
theTarget = $Camera001 -- the target
for p = 1 to count do
local dum = dummy()
pfSys.particleIndex = p
pPos = pfSys.particlePosition --get particle pos
tm = matrixfromnormal theTarget.dir --get the camera matrix3
new_TM = matrix3 tm.row1 tm.row2 tm.row3 pPos
dum.transform = pfSys.particleTM = new_TM
SOLUTION
on ChannelsUsed pCont do
pCont.useTime = true
pCont.useSpeed = true
pCont.useTM = true
pCont.usePosition = true
on Init pCont do
on Proceed pCont do
count = pCont.NumParticles()
source = $Camera001
for i in 1 to count do
pCont.particleIndex = i
tm = source.transform
pos = pCont.particlePosition
new_TM = matrix3 tm.row1 tm.row2 tm.row3 pos
pCont.particleTM = new_TM
Maybe
I think is better to use
then
I essentially want the particles to act as if they had an Orientation constraint on them so that they are always facing camera but also have the rotation to be parallel on all sides to match that of the camera.
I tried this but its way to intense to do on large particle counts and actually doesn't orient the particles correctly.
pfSys = ($PF_Source_001)count = pfSys.NumParticles()
local dum = dummy()
local theTarget = $Camera001 -- the target
tm = theTarget.transform --get the camera matrix3
Please, screenshoots if you don't mind.
