Hi Everyone,
Through the last few years of experience using 3dsmax and Vray, I have some custom setting that I use in almost every project, and I am planning to customize 3dsmax and Vray to those setting so I could let my colleague using it. These are some example of things that I would like to change:
[a] vray light setting
[b] vray material setting
Create a rollout of light or material preset/setup is good, but what I hope is to override the original button and setting so my colleague don't need to change their habit of work. Here's some of my idea for it:
[1] vray light | create the light by pressing the same button, but the setting is customized, or it will create a vraylight with rig setup
[2] vray material | vray material is created with customized setting every time they create a new one
Could you advice, or give me an idea or a hint of direction of which way should I dig into?
Thank you very much!
Appreciate that Farjar, I will try now.
using callbacks u can do that.....
clue on...
#nodeCreated: node
or you could modify "vrayutils.ms" in maxfolder/scripts/startup
after finishing your script , then share it to your friend, show it how to install and thats all, no need to change the way your friend work.
here is vray light properties that you might want to change
